Cadplan Architecture Posted August 17, 2021 Share Posted August 17, 2021 Is there a simple way to change the orientation of all the design layers by 180deg permanently so that they stay aligned? I don’t mean rotate plan. Quote Link to comment
TomKen Posted August 17, 2021 Share Posted August 17, 2021 Turn on all your layers and classes, Set the layers to show snap modify others. Select everything and rotate 180 degrees. Quote Link to comment
Pat Stanford Posted August 17, 2021 Share Posted August 17, 2021 If you have layers at different scales that you need to keep aligned you might need to do it on a layer by layer basis. I would consider dropping a locus point on each layer at the "center of rotation" and then Select All with layer options set to Active Only and use the Rotate tool and the locus point to make sure you rotate each layer around the same point. Quote Link to comment
