escaping quotes for record format criteria
I'm really struggling with escaping quotes properly. I want to perform some actions on symbols that have a certain record format field, but I cannot seem to get the criteria to work using ForEachObject.
Im using selCriteria:=concat('CPA Products'.'Serial'=,RF1) as the criteria where selCriteria is the selection criteria and RF1 is a string variable for the record format field contents. Because of all the record format quotes, I cannot seem to get it to work no matter how I try to escape them. Any help would be appreciated.
Or my favorite, CHR(39) 😉
CHR(39) puts in ascii character which is the single quote.  So my version would look something like:
selCriteria:=Concat(CHR(39),'CPA Products',CHR(39)'.',CHR(39),'Serial',CHR(39),'=',RF1);
I just use CHR(39) where quotes are actually needed in the final string.
To debug, I use AlrtDialog(selCriteria); to see what is actually being produced.
double and triple single quotes are great after you get them working correctly, but they are such a pain to try and read and differentiate. CHR(39) is typing a little more, but you then know exactly what you are doing at a glance.
Per Pat's suggestion of using chr(39), you can make a "const" declaration of "k39"= chr(39)" which makes is example a tiny bit easier to implement;
CONST
    k39 = chr(39)
VAR
    asdfasdf
BEGIN
    selCriteria:=Concat(k39, 'CPA Products', k39, '.', k39, 'Serial', k39, '=', RF1);
END;
Suggestion: spaces after commas have no effect but make the function parameters easier to read.  Pat is missing a comma after the second CHR(39).  That happens to me all the time setting up criteria strings.
Thanks for the extra hint Sam. You could even set the Const to be something like a capital Q so it is not even any extra characters to type.
Julian, now that you mention it, that sounds vaguely familiar to me also. A quick search didn't turn up anything in my archives either though. I will keep looking. I want to say that perhaps is was not done in VS, but rather though BBEdit or something else?
