bohlr Posted February 26, 2004 Share Posted February 26, 2004 I have a roof surface that will not render with a shingle texture that is attached to it, yet a roof surface created with the roof tool with the same texture renders just fine. Any suggestions? Quote Link to comment
P Retondo Posted February 26, 2004 Share Posted February 26, 2004 Is your surface set to "Fill - None"? Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted February 26, 2004 Vectorworks, Inc Employee Share Posted February 26, 2004 quote: Originally posted by bohlr: I have a roof surface that will not render with a shingle texture that is attached to it, yet a roof surface created with the roof tool with the same texture renders just fine. Any suggestions? What do you mean, "will not render"? Does it render as a solid object without the texture, or does it look like a wireframe? Quote Link to comment
bohlr Posted February 27, 2004 Author Share Posted February 27, 2004 Thank you for the responses. Changed fill to "class style" and roof face changed from previous solid color fill to the class fill style "shingles". Problem solved. Quote Link to comment
