Nina Agelvis Posted August 9, 2021 Share Posted August 9, 2021 Hello! I was wondering if it is possible to add a new field in the Object Info Pallet for devices. I created a new label legend with an added field to the dev_rec Record Format called IP Address. Linking the text to the record format was fine and I was able to change the label legend on the device, but I realized I couldn't fill in the IP Address field because it doesn't show up in the Object Info Pallet, or in the records tab. If I double click on the device I don't have access to change the information on the legend label. For now I'm just going to add a text box to each symbol, but I really hope there is a way to add a new field and be able to fill it in. Thank you! Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 10, 2021 Vectorworks, Inc Employee Share Posted August 10, 2021 Hello @Nina Agelvis, Check this topic, it is exactly about this - You can check the other posts in the Did you know section too, as they should be useful in getting to know with ConnectCAD. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
