If Node Test
I've been looking for a bit but haven't found any current threads about this so if it exists please route me.  I'm trying to create an if node with a test.  I can't figure out how to input my test.  currently it is just a simple "if x>=Y then Z+1, Z". if that makes sense.  I am looking for just a nudge in the right direction as I can't figure out the correct way to approach this.
Thanks in advance for your time!
This is exactly what I was missing!  Thank you so much.  I did not realize there was a specific node that did that but rather a general node you would input the test into.  Still wrapping my head around the logic on a lot of things but this helps so much.  Thank you @sbarrett
