Expand or Collapse Widget Group
Yes there is. The PIO must be event-enabled. I'm doing this in Python, but it should also work in Vectorscript.
In the Event 5 (kObjOnInitXProperties) routine, include these 3 lines:
Python:
_bResult = vs.SetObjPropVS(8, True)  # kObjXPropHasUIOverride
_bResult = vs.SetObjPropCharVS(81, vs.Chr(2))  # kWidgetGroupMode, kWidgetGroupAutomatic
object_info_palet(_sPIOName)
Vectorscript:
bResult = SetObjPropVS(8, TRUE);  {* kObjXPropHasUIOverride *}
bResult = SetObjPropCharVS(81, Chr(2));  {* kWidgetGroupMode, kWidgetGroupAutomatic *}
ObjectInfoPalet(sPIOName);
The last line calls these procedures. At least that's how I do it.
Python:
def object_info_palet(_sPIOName):
    _iPIOID = 100
    _iPIOID = insert_separator(_iPIOID, _sPIOName, "Global", 0)
    _iPIOID = insert_parameter(_iPIOID, _sPIOName, "LineLength", 1)
    _iPIOID = insert_parameter(_iPIOID, _sPIOName, "Diepte", 1)
def insert_separator(_iID, _sPIOName, _sParameter, _iIndent):
    _bResult, _sTmp = vs.GetLocalizedPluginParameter(_sPIOName, _sParameter)
    if _bResult:
        _bResult = vs.vsoAddWidget(_iID, 100, _sTmp)
        _bResult = vs.vsoAppendWidget(100, _iID, _sTmp, 0)
        vs.vsoWidgetSetIndLvl(_iID, _iIndent)
    return _iID+1
def insert_parameter(_iID, _sPIOName, _sParameter, _iIndent):
    if _bResult:
        _bResult = vs.vsoAddParamWidget(_iID, _sParameter, "")
        _bResult = vs.vsoAppendParamWidget(_iID, _sTmp, 0)
    return _iID+1
Vectorscript:
PROCEDURE ObjectInfoPalet;
VAR
	iPIOID: INTEGER;
BEGIN
    iPIOID := 100;
    iPIOID := InsertSeparator(iPIOID, sPIOName, 'Global', 0);
    iPIOID := InsertParameter(iPIOID, sPIOName, 'LineLength', 1);
    iPIOID := InsertParameter(iPIOID, sPIOName, 'Depth', 1);
END;
FUNCTION InsertSeparator(iID: INTEGER; sPIO, sField: STRING; iIndent: INTEGER): INTEGER;
VAR
    bResult: BOOLEAN;
    sTmp: STRING;
BEGIN
    bResult := GetLocalizedPluginParameter(sPIO, sField, sTmp);
    IF bResult
    THEN BEGIN
        bResult := vsoAddWidget(iID, 100, sTmp);
        bResult := vsoAppendWidget(100, iID, sTmp, 0);
        vsoWidgetSetIndLvl(iID, iIndent)
    END;
    InsertSeparator := iID + 1;
END;
FUNCTION InsertParameter(iID: INTEGER; sPIO, sField: STRING; iIndent: INTEGER): INTEGER;
VAR
    bResult: BOOLEAN;
    sTmp: STRING;
BEGIN
    IF bResult
    THEN BEGIN
        bResult := vsoAddParamWidget(iID, sField, '');
        bResult := vsoAppendParamWidget(iID, sTmp, 0);
        vsoWidgetSetIndLvl(iID, iIndent);
    END;
    InsertParameter := iID + 1;
END;
I hope the Vectorscript is correct, I do more Python these days.
