cwailes Posted August 9, 2021 Share Posted August 9, 2021 For some reason when I run this command the walls do not go all the way to the underside of the roof. It leaves about a foot or more below the bottom of the roof. What could be causing this? Quote Link to comment
Boh Posted August 9, 2021 Share Posted August 9, 2021 Do you have some object there that are in a class set to invisible? The fit walls command will fit to all objects regardless of their current visibility settings. Quote Link to comment
taoist Posted August 9, 2021 Share Posted August 9, 2021 12 hours ago, ccw said: For some reason when I run this command the walls do not go all the way to the underside of the roof. It leaves about a foot or more below the bottom of the roof. What could be causing this? Are you referencing the correct layer to fit walls to roof? You need to tell the tool/command what layer to fit objects to. Quote Link to comment
