Circle pCenter Confusion
Dendecko
Hello,
I'm building a repeating set of circles on a Y axis but my circles are appearing in different X axises even though they have the same x point going into them any ideas what I might be doing wrong?  picture to explain. all circles should appear on same x position but different Y positions however that is not what is happening.
difficult to find the problem with such a small section.
Here is an example of placing a number of circles
I don't understand the <add> part - it always generates the same number, so why not enter the sum directly as a real or dim
greatings
M.Graf
 series.vwx
Edited by m.graf
@m.grafHey, totally I was just trying to show the exact challenge by zooming in and showing the 3 had the exact same real number input for the x position while having different y positions.  The larger script I think was just going to confuse what I was trying to do.  It unfortunately turned out to be an in session bug.  When I closed vectorworks and restarted it, it worked correctly.
