Kevin McAllister Posted August 4, 2021 Share Posted August 4, 2021 Hello all, This is my first time using Data Visualization. I would like to colour code a pattern of extrudes of various depths. Is there an easy way to create the criteria for this? Thanks, Kevin Quote Link to comment
markdd Posted August 5, 2021 Share Posted August 5, 2021 Kevin Will this work for you? 1 Quote Link to comment
Kevin McAllister Posted August 5, 2021 Author Share Posted August 5, 2021 @markdd thanks for your reply. Unfortunately none of the functions seem to work for my scenario, where the extrudes are plant on details distributed on a facetted wall 🙂. I really need access to the "extrude" variable of an extrude. I came up with a workaround using classes with Data Visualization for now, but in all honesty, its actually more complicated than the manual solution of colouring the extrudes manually by class. I was hoping for something that would update automatically as I adjusted the depths of the various elements through the design process. Kevin Quote Link to comment
markdd Posted August 5, 2021 Share Posted August 5, 2021 I suspected as much! I wonder if there is a way to push the depth value to an attached record using the Data Manager. I had a quick look but couldn't find the criteria. I am sure someone cleverer than me will know the solution with that. Once the data is in a record then all should be well with the data visualisation. 1 Quote Link to comment
