Ben3B Posted August 4, 2021 Share Posted August 4, 2021 (edited) Hello is a way to automaticly add a class to speakert object added with speaker tool ? When I add a speaker as symbol hybrid 2d/3d, the class is created, but with the tool the class isn't. Edited August 4, 2021 by Ben59 Quote Link to comment
C. Andrew Dunning Posted August 5, 2021 Share Posted August 5, 2021 Have you tried using the "Classes..." button at the bottom of the OIP? You can assign some or all of the parts to Classes using that dialog. Quote Link to comment
Ben3B Posted August 6, 2021 Author Share Posted August 6, 2021 hello thanks for answer ! Are talking about "classes part" at the bottom of the OIP and int the configuration tool ? if so, it only works for part of the plugins... I'm looking for the same menu as when I right click on a plug-in and choose plugin option ... It will be nice if that menu's option will be in the configaration menu and by the way OIP Quote Link to comment
C. Andrew Dunning Posted August 7, 2021 Share Posted August 7, 2021 On 8/6/2021 at 7:49 AM, Ben59 said: hello thanks for answer ! Are talking about "classes part" at the bottom of the OIP and int the configuration tool ? if so, it only works for part of the plugins... It will be nice if that menu's option will be in the configaration menu and by the way OIP Yes, that is what I meant. Sorry, the functionality you're wanting isn't part of the mix at this time... Quote Link to comment
