How to get the (data) tagged object?
When tagging an object using a data tag, a connection between the two is established.
I'd like to find a way to get the handle of the objects that was tagged by a certain data tag.
In my mind a command could look like this
hTaggedObj = vs.DT_GetAssociatedObj( hDT )
The only commands about data tags I could find in the developer wiki are these two:
https://developer.vectorworks.net/index.php/VS:DT_AssociateWithObj
https://developer.vectorworks.net/index.php/VS:DT_UpdateTagsOfTagged
The List View Ex dialog of the debug mode wasn't much help either.
  • 1 month later...
What about this:
def IsTagged(h):
    result = False;
    num = vs.GetNumAssociations(h)
    assH = None
    assKind = None
    value = None
    i = 0;
    while(i < num and result == False):
      assH, assKind, value = vs.GetAssociation(h, i);
      if (assKind == 37):
        result = True;
        i = i + 1;
        return result, assH;
This would help finding Tagged Object. This was some I found in the Forum here. It works in a Marionette Object, which is inside a DataTag to find the tagged Object. So I think you could loop all Objects and check with vs.GetAssociation() type 37. Then you have the Tag and could check the Kind of Tag.
  • 5 months later...
This one, used while in Annotations, uses the selexted Datatag and jumps to the tagged Object in yours Model and select it.
import vs;
objs = []
def Name(h):
	hLayerObj = vs.GetLayer(h)
	hLayerAct = vs.ActLayer()
	vs.AlrtDialog(vs.GetName(h))
	hAss, iAssKind, iAssVal = vs.GetAssociation(h, 0)
	if hAss != 0:
		objs.append(hAss)
vs.ForEachObject(Name, "((INSYMBOL & INOBJECT & INVIEWPORT & (VSEL=TRUE)))")
if len(objs) == 1:
	hLayObjs1 = vs.GetLayer(objs[0])
	vs.DoMenuTextByName('Group Navigation Chunk', 2)	#Verlasse Ergänzungen
	vs.Layer(vs.GetLName(hLayObjs1))					#Wechsel Ebene
	vs.SetPref(94, True)								#Aktuivere Modellansicht
	vs.SetPref(14, True)								#Zeige Objekte auerhalb Gruppe
	vs.DSelectAll()
	for x in objs:
		hParObj = vs.GetParent(x)
		iTypParObj = vs.GetTypeN(hParObj)
		if iTypParObj == 11:
			vs.SetSelect(hParObj)
			vs.DoMenuTextByName('Group Navigation Chunk', 1)
		if iTypParObj == 15:
		vs.SetSelect(x)
		vs.DoMenuTextByName ('Fit To Objects', 0)
Hope this one is helpful. Have fun,
Heiko Jakob
