J. Miller Posted August 1, 2021 Share Posted August 1, 2021 Is there a way to publish a group of pages as rasterized (flattened) PDF's? I have a 23 page file that need to be rasterized as in pdf. Thanks Jeff Quote Link to comment
Art V Posted August 1, 2021 Share Posted August 1, 2021 When in the publish dialog, click on the sheet layers you want to be rasterized and then click on options behind PDF below the list of sheets to be exported. You will then get the following dialog At the top there is an option to rasterize the PDF you want to publish, select it and you should get a rasterized sheet. If you do this for all PDF sheets you should have a fully rasterized PDF file. Quote Link to comment
J. Miller Posted August 14, 2021 Author Share Posted August 14, 2021 Thanks, Some file are getting so large now i need to do this to provide to clients using smaller machines Quote Link to comment
