buz Posted January 20, 2004 Share Posted January 20, 2004 How do I put Detail Markers, Drawing Labels etc into a Section drawing? Every time I select some sort of marker or label and click to place it, the 'section' automatically reverts to plan view. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted January 21, 2004 Vectorworks, Inc Employee Share Posted January 21, 2004 If you are using "cut 3D section" to create your section, this creates a group of 3D polygons. Use Rotate 3D so that you're looking at the section the way you want when the layer is in Top/Plan view. If you're using layerlinks to get your "section" view, then use the Model View Tool instead and choose the view you want in the Model View Tool. (The layer will still be in top/plan view.) Quote Link to comment
