NoemiM Posted July 30, 2021 Share Posted July 30, 2021 (edited) Hi there, I am loving Vectorworks site Modelling + Lumion rendering, but I am really struggling with the sync. Has anyone found a way to re-sync the Lumion + Vectorworks file without losing all the materials on Lumion? Every time I have to re-sync a project (e.g. after a tweak to the vws masterplan), I loose all the materials I previously applied on Lumion, but I keep the objects (e.g. peoples and plants). Any help is greatly appreciated. Noemi Edited August 4, 2021 by NoemiM Quote Link to comment
bcd Posted July 31, 2021 Share Posted July 31, 2021 VW-Lumion is sweet! If you're running Wndows and have a spare hour for a testdrive you'll be blown away. I have seen this mapping error happen before but not for a while. If you change the texture/color of an object in VW it breaks the material mapping in Lumion but the wholescale loss of mapping is a different animal. Do you lose the VW Texture->Lumion Material mapping every time or just sometimes? Will it happen in a test file after a restart of your machine? Are both files saved and using static file names? Do you keep both files open at the same time - you should be able to tweak the master VW and see the changes reflected in the Lumion almost immediately. You have the option to bypass LiveSync and instead export a Collada (dae) file from the latest version of your VW file and import this to Lumion. 2 Quote Link to comment
Carol Reznor Posted November 3, 2021 Share Posted November 3, 2021 @NoemiM Hi - I am curious in how you solved the problem you were having. You care to share? Thanks! Carol Quote Link to comment
bcd Posted November 3, 2021 Share Posted November 3, 2021 Interesting you ask, this just happened to me this morning with VW2020 and Lumion 12. I'm not sure if it was because I didn't commit the save from Lumion properly or I started with a VW file from 2021, or I need to restart after installing Lumion 12. Are you LiveSyncing from VW->Lumion or exporting a file? I do notice that after making changes in the Lumion file I get the Save as... button but not the Save button which is really odd ... I'll test it again to see Quote Link to comment
Vectorworks, Inc Employee LDraminski Posted November 1, 2022 Vectorworks, Inc Employee Share Posted November 1, 2022 Hello all, If anyone in this 'string' is using Lumion + Vectorworks, please let me know. Thank you in advance, Lee Quote Link to comment
