Hello Community!
This Thursday, October 21st, from 6 pm to 7 pm EDT, we will be performing an update on the Vectorworks Community Board. During this time, the site will be unavailable.
adding a dimension to a record
Hello everyone, I've tried looking this up on the forums but I might be looking for the wrong searchterms.
I've never worked with records and so far I feel like it can really increase my workspeed.
Example: I have created a symbol to block-out bookshelves. It is a generic symbol and I use a dimension to display the length so that when i stretch the symbol, the measurement updates automatically (great so far!). I made a record listing some information and I would love to have the dimension being reported here, so I could later add for example some formulas calculating the amount of books.
I haven't figured out how to get the dimension into the record, is there a way to get it done or a different approach?
Show us the criteria you are using. In the Criteria dialog box there is a check box for Show Objects in Symbol. You will definitely need to check that. You will probably also need to assign those dimensions to a special class.
There is not easy way to get a single database row to display information about a symbol and about the items inside that symbol in a single database row.
It would be  possible to write a worksheet script that will report the information you want.
Thank you for your reply, this is all quite new for me so I'm sorry if I might be approaching this all wrong.
I have been experimenting a bit further, I wasn't aware of how to make a report without a record yet, but I found out how and I have made a simple basic report.
Now I have a report which lists all the lines in a certain class and reports the length of these in the table,
I also managed to make a calculation like I would in excel, however this only takes the total length in account.
The most ideal situation would be if I could have a specific calculation (like the example in the image) applied to every seperate object (2.1, 2.2, etc) and if I could somehow make the outcome of such calculation appear as a number on the object (as a tag maybe?). Currently I do this manual almost weekly, I would be open to scripting it but since I have almost no experience with vectorworks scripting I'd have no clue where to start.
Database subrows are special. There is no way outside of that specific row to grab the data that is in the subrow.
If you put your formula in column B of the database header row (B2, not B2.1, 2.2, etc). then you should get the value for each subrow displayed.
Ask again if you need more help.
