hollister design Studio Posted July 29, 2021 Share Posted July 29, 2021 1. Is there a way to set title block revision numbers to 'numbers' instead of letters? Found it in 'Title Block Border Settings" document option tab. 2. Is there a setting so that the revisions can be set to be the same on every sheet? Thanks! Quote Link to comment
Boh Posted July 29, 2021 Share Posted July 29, 2021 You can use the title block manager to do multi-sheet revisions. The manager interface is a bit non-intuitive. First thing to do when the dialogue opens is to hit the "Select Sheets" button which is right at the bottom of the dialogue. Once you have selected which sheets you want to add revisions to you can do the same revision to all of them. 2 Quote Link to comment
hollister design Studio Posted July 29, 2021 Author Share Posted July 29, 2021 21 hours ago, Boh said: ...the manager interface is a bit non-intuitive... I've turned and run every time I've accidentally opened it. Will have to dive in I guess. 1 Quote Link to comment
