SimonBarrington Posted July 28, 2021 Share Posted July 28, 2021 Does anyone have a manageable library of Roe CB5 in t4 Touring Frames. I have tired to glue together the DWG I have been sent of the touring frames along with the VW file of CB5. Once you get to a big screen, the file size makes the VW so slow. Quote Link to comment
scottmoore Posted July 31, 2021 Share Posted July 31, 2021 The trick is to simplify the geometry to give you enough detail to know what the item is but not so much that it ruins your processing. Avoid curves, arcs, circles and all the connection fittings. If you need that level of detail then create two versions, one simple, one detailed and class them prior to creating your symbols. That way you can choose the level of detail for output purposes. Quote Link to comment
