CC Cooperstock Posted July 27, 2021 Share Posted July 27, 2021 Hello- I just changed out some truss from 10' to 8' and now the lights are under the truss so I can no longer see the channel numbers, addressing or cabling information. How do I get the lights symbols to be on top of the truss? Quote Link to comment
Jesse Cogswell Posted July 27, 2021 Share Posted July 27, 2021 You can select the truss and right-click on it and select Send - Send to Back or use the shortcut (Ctrl+B on Windows, Command+B on Mac). What I commonly do is put lighting positions and fixtures on separate layers so that there is no possibility of having the position go on top of the fixtures. Quote Link to comment
CC Cooperstock Posted July 27, 2021 Author Share Posted July 27, 2021 Thanks so much!!! Quote Link to comment
Ben3B Posted July 28, 2021 Share Posted July 28, 2021 Also you can put lights and truss on different layer, and then the layer order/number is the viewing order Layer 1 on top layer 2 below 1 layer 3 below 2 ... Quote Link to comment
