Sam Jones Posted July 25, 2021 Share Posted July 25, 2021 I have created and am good with event enabled point objects and path objects. Is anyone willing to share a tool template, or instruction on the difference between an event enabled PIO tool and an event enabled PIO object. It seems likely that tools are not event enabled, since they do not persist, but a simple example would be good. TIA, Sam Quote Link to comment
JBenghiat Posted July 25, 2021 Share Posted July 25, 2021 Sam, see this thread: Note, you need a hex editor to enable an event-based tool. The biggest feature of the event enabled tool is customizing the mode bar, as well as handling multiple clicks easier to work with. Many of the limitations are still there though, for example, the code still doesn't run until after the first click. Quote Link to comment
SamIWas Posted July 28, 2021 Share Posted July 28, 2021 On 7/25/2021 at 7:55 PM, JBenghiat said: Note, you need a hex editor to enable an event-based tool. The biggest feature of the event enabled tool is customizing the mode bar, as well as handling multiple clicks easier to work with. Many of the limitations are still there though, for example, the code still doesn't run until after the first click. I just want code to run when an object is duplicated, so my objectID checker will run. But every time I see one of those event-enabled scripts, my mind turns into spaghetti. Quote Link to comment
JBenghiat Posted July 28, 2021 Share Posted July 28, 2021 2 minutes ago, SamIWas said: I just want code to run when an object is duplicated, so my objectID checker will run. But every time I see one of those event-enabled scripts, my mind turns into spaghetti. @SamIWasYour own object or any object? Quote Link to comment
SamIWas Posted July 29, 2021 Share Posted July 29, 2021 17 hours ago, JBenghiat said: @SamIWasYour own object or any object? My plugin objects. I have custom point-object tools I use for racks, cables, optos, network units, consoles, nodes, etc. In order to make them import/export with FileMaker Pro (where I have an extensive database I use to track every piece), I have a UUID procedure within the tool which assigns a UUID to the object in one of the fields, and as an object name. The object name will change automatically If duplicated, and the procedure will check to see if the ID and name match, and generate a new ID if they do not. But I need the UUID procedure to run again after duplication to make the ID unique to each object. But it won't run unless I change some data. HOLY CRAP. I thought I had tested this before multiple times and it didn't work...but checking "Reset on Move" and "Reset on Rotate" does fix that issue. Now to go update all my plugins! 1 Quote Link to comment
