Ride Posted July 22, 2021 Share Posted July 22, 2021 I tried to edit my section marker style, and now the alignment is off. Why? It looks fine in the edit window. VW2021SP4 Architect/InteriorCAD Quote Link to comment
0 Pat Stanford Posted July 22, 2021 Share Posted July 22, 2021 It looks like you moved everything. Edit them again and make sure that the center of the circle is set at the "local" 0,0 point of the edit window. Everything else should be based off of that location. Quote Link to comment
0 Ride Posted July 23, 2021 Author Share Posted July 23, 2021 Hmm. It is at 0,0. Do you see anything else wrong with the settings below: Quote Link to comment
0 Pat Stanford Posted July 26, 2021 Share Posted July 26, 2021 I can't tell in your latest screen shot as I can't see the vertical axis, but in the one from Thursday, it definitely looks like the center line and the black triangle (and probably everything else) is offset vertically from the zero point. Quote Link to comment
Ride
3 answers to this question
