Garrett Burleson Posted July 21, 2021 Share Posted July 21, 2021 (edited) Hi All, Has anyone else run into the issue of Renderworks Textures not displaying on the default VW cabinetry? Screenshot attached. For the selected cabinet, the texture does not show. Note that the upper cabinets do have a texture applied but that was after I ungrouped them - making subsequent changes to the cabinets too cumbersome. I also tried applying a 'Class Texture' - same results. Has anyone found a work around? Am I missing something? Best, Garrett Edited July 21, 2021 by Garrett Burleson Quote Link to comment
zoomer Posted July 21, 2021 Share Posted July 21, 2021 First thought. Just assigning a Texture to a Class may not be enough. The Class also needs "use Class Attributes" activated and you may want to check if all geometries Attributes are set to "by Class" - not by object. But Cabinetry are PIOs, don't they have options to apply Classes for different parts, like each part of Stairs or Windows ? Quote Link to comment
Garrett Burleson Posted July 21, 2021 Author Share Posted July 21, 2021 Thanks Zoomer - your last statement regarding applying classes for different parts did the trick. In the object info pallet there is a dropdown for 'cabinet' and 'doors' - this has to be assigned the appropriate class and then the class texture works - see attached image. I think this workflow is a little illogical - we are already setting the overall class for the cabinet, so VW should automatically assign this to the Cabinets and Doors (it seems like a simple if/then statement would accomplish this). Also, our projects never have different colored cabinets and doors. Thanks for your insight. -Garrett 1 Quote Link to comment
