JimDenaultASC Posted July 20, 2021 Share Posted July 20, 2021 Is there still an issue with DMX Footprint values in 2021 SP4? Using stock VW Library Arri Skypanel S-60 C symbols, the DMX Footprint is grayed out with a zero value no matter whether I have a Fixture Mode selected or not. Mode 6 should have a footprint of 20, but shows as zero. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted July 21, 2021 Vectorworks, Inc Employee Share Posted July 21, 2021 Make sure the Fixture Mode and the GDTF Fixture are both set to None to enable manually setting the DMX Footprint. If there is a fixture profile set then Vectorwork will use the data from the fixture profile. I set the Fixture Mode to Arri Skypanel S-60 C m6 and the footprint was automatically populated with 20 and disabled. When I switched back to None the filed was manually editable. Quote Link to comment
