Sloader Posted July 15, 2021 Share Posted July 15, 2021 I I would like to duplicate a viewport (linked to a camera) and change the rotation of the camera in the new viewport From the reference I have found VS:GetViewMatrix and VS:SetViewMatrix and managed to get, change and set the rotationXAng parameter but it doesn't change the direction of the camera. Hoffset = 0.117236 Y =0 viewport = vs.FSActLayer() VPparams = vs.GetViewMatrix(viewport) VPparamsList = list (VPparams) Myoffset = VPparamsList[1] MyrotationXAng = VPparamsList[2] MyrotationYAng = VPparamsList[3] MyrotationZAng = VPparamsList[4] MyrotationYAng = 45 VpCylR1 = vs.HDuplicate(viewport,Hoffset,Y) vs.SetViewMatrix(VpCylR1, Myoffset, MyrotationXAng, MyrotationYAng, MyrotationZAng) VpCylR2 =vs.HDuplicate(viewport,Hoffset*2,Y) VpCylR3 =vs.HDuplicate(viewport,Hoffset*3,Y) VpCylL1 =vs.HDuplicate(viewport,0-Hoffset,Y) VpCylL2 =vs.HDuplicate(viewport,0-Hoffset*2,Y) VpCylL2 =vs.HDuplicate(viewport,0-Hoffset*3,Y) Quote Link to comment
Pat Stanford Posted July 19, 2021 Share Posted July 19, 2021 It is very likely there is a one way link between the camera and the viewport. Changing the viewport will likely not make changes to the camera. I played with it a little, but I did not find the proper incantation to get the viewport to update based on scripted changes to the camera. You can get a handle to the camera using def vs.GetVPGroup(viewportHandle, groupType): return HANDLE with a groupType of 10. Using the handle to that object you can change the settings of the camera, but the Viewport does not update until you manually select the Edit Camera option. I have tried all the tricks I know about resetting objects from the Camera all the way up and nothing has worked. Good Luck. Quote Link to comment
Sloader Posted July 20, 2021 Author Share Posted July 20, 2021 Thanks for trying, I can't see how I would ever have found vs.GetVPGroup would get a handle to the cameras - shame the view doesn't update. I have been trying to use vs.SetViewMatrix with the cameras deleted which does update and I can make incremental changes to the views but I haven't figured out how to make a simple 20degree rotation. I did the rotations manually then checked the parameters and it seems it isn't just the Y Rotation angle that changes. The sequence of parameters below are for a set of cameras rotated 20 degrees - I can't figure out why the offsets (X,Y,Z) change RotX=-90.0RotY=90.0RotZ=0.0X=415369.5 Y=94456.215 Z=105.2183062590922 RotX=90.0RotY=70.0RotZ=180.0X=415341.2491173034 Y=94456.215 Z=66.99958883375739 RotX=90.0RotY=50.00000000000002RotZ=180.0X=415301.6304000912 Y=94456.215 Z=40.748113042233484 RotX=90.0RotY=30.000000000000018RotZ=180.0X=415255.4224503691 Y=94456.215 Z=29.630194295498455 Quote Link to comment
