I would greatly appreciate some insight into a problem I have with using the Split tool on 3D objects.
I attach a Vectorworks (2018) file. It contains two 3D solid section objects. After activating the Split tool, in either Line Split or Line Trim mode, both objects will highlight red when hovering the cursor over the object. However, only one of the objects will actually split into multiple objects. I can't figure out why!
Does it have something to do with the type &/or number of historic editing operations used to create the current object?
Dundee901
Thank you.
Split solid section.vwx
2 answers to this question
