{ Error: The operands are not of compatible types. }
I'm getting this error message in unexpected places.  Including functions with no operands.  For example in a solid subtraction:
		tempHandle1 := LObject;
		tempHandle := PrevObj(tempHandle1);
		result := IntersectSolid(tempHandle, tempHandle1, tempHandle2);
		ResetOrientation3D;
		Rotate3D(#0.0000000000000d,#-0.0000000000000d,#0.0000000000000d);
		Move3D(0",0",0");
I'm getting that error on the line ResetOrientation3D;  I've experienced a lot of error messages 🙂 and so I'm aware that the error is often in a nearby line, but I don't see where.  All the tempHandles are defined as handle variables.
Also here:
		result := SubtractSolid(tempHandle, tempHandle1, tempHandle2);
		BeginXtrd(0",0.05");
			RectangleN(-0.656",0.341641697326893",0.039370078740157",0",1.312",0.054089086164082");
			NoShadows(LNewObj);
			objectHandle := LNewObj;
			SetObjectVariableBoolean(objectHandle, 1160, FALSE);
			boolResult := SetEntityMatrix(objectHandle, 0",0",0",0,-0,0);
		EndXtrd;
		ResetOrientation3D;
		Move3D(0",0",0.248855109792259");
BeginXtrd(0",0.05"); gets the same error message.
As is my wont, I copied all this from a script export 🙂, which makes the error message even more puzzling.
Anybody know what's going on here?
Sorry for the delay.  Time zone weirdness :-).
I added a procedure, run, begin, end and VAR declarations.
PROCEDURE TEST;
VAR
objectHandle,tempHandle, tempHandle1, tempHandle2
: HANDLE;
boolResult, result
: BOOLEAN;
BEGIN
NameClass('None');
BeginXtrd(0",0.3");
PenSize(2);
PenPatN(2);
FillPat(1);
PenFore(0,0,0);
PenBack(65535,65535,65535);
FillFore(0,0,0);
FillBack(65535,65535,65535);
RRectangleN(-0.656",-1.294",0.039370078740157",0",1.312",2.588",0.2",0.2");
SetDropShadowData(objectHandle, 0,0.003937,0.001969,#315.0000000000d,75,0,0,0);
EnableDropShadow(objectHandle, FALSE);
EndXtrd;
ResetOrientation3D;
Move3D(0",0",0");
BeginXtrd(-0.656",0.675744405755057");
OvalN(-4.704541031598826",-1.874808580246114",0.039370078740157",0",1'1.579999999999998",2.1725");
EndXtrd;
ResetOrientation3D;
Rotate3D(#90.00000000000d,#-0.0000000000000d,#90.00000000000d);
Move3D(0",0",0");
ResetOrientation3D;
Move3D(0",0",0");
RectangleN(-0.504",0.468",0.039370078740157",0",1.008",0.65");
EndXtrd;
ResetOrientation3D;
Move3D(0",0",0.25");
EndXtrd;
ResetOrientation3D;
EndXtrd;
ResetOrientation3D;
Move3D(0",-0.661641697326893",0.210077178945487");
ResetOrientation3D;
Rotate3D(#90.00000000000d,#-0.0000000000000d,#180.0000000000d);
Move3D(0",0",0");
END;
RUN(TEST);
result should have a variable type of Integer instead of Boolean.
The IntersectSolids and SubtractSolids return an Integer.
Also, there seems to be a lot of extra junk.  Why are you applying DropShadows before you extrude? Isn't Drop Shadow a 2D only thing?
Also, there are a couple of places where it looks like the LNewObj is being used twice in a row.
