decayny
Window Plug-in problems
I always get an error output message when attempting to use the window plug-in object. It also happens with any window plug-ins pasted form other documents [created in VW 10.5 on OS9.2.2] - I can't edit them and if I move them out of the wall they disappear - although there info still shows in the Info pallette until i hit the delete key.
I don't have this problem w/ the simple or complex window objects.
I'm using VW10.5 on a Powerbook G-4 running OS 10.2.6
The objects may be disappearing because of class visibility issues (i.e., the window and door PIOs often create classes you didn't have before, and which will be invisible in all of your sheet setups). Objects that are members of non-visible classes are often visible when first inserted into a drawing, but become invisible the moment you try to do something.
