James and doors visable
I updated a plan from an older version and the door frames do not view correctly. The original file started as a v2009. Updating to v2021 i have the problem. I tried updating to v2015 and the frames and jambs showed correctly. Then I updated to v2019 and everything looked correctly, but when I tried updating again to v2021 i still had the problem.
Any idea what the problem is?
Document Preference: Display pane.  You can set the detail level to automatically display differently in different design layer scale ranges.
If this prefernce is unchecked then I think it is the same as saying High detail, but I am not certain.
Doors and Windows are the same in Medium and High detail.
