dennisp Posted May 22, 2005 Share Posted May 22, 2005 The current file is not sending all the info to the printer. A previous file is fine, and it sends the info over in regular increments (eg. 10%, 22%, 33%, etc). The current file gets to 22% and thats all, the design prints only that portion of the info. ???? I have printed about 40 designs, this has happened to about 3. In the past I was able to change paper size and print the design out in segments. My plotter is an HP designjet 100. Quote Link to comment
IanH Posted May 31, 2005 Share Posted May 31, 2005 Are you using print spooling? If so, it may be worth creating a copy of your printer but with the spooling option off - it is under the ports tab. It is possible that for larger print requirements you are running out of memory to hold the spooled data and the print just gives up. You could temporarily turn off print spooling on your current printer to test this theory this out first. Having spooling turned off means that the print command does not return control back to you until it has physically finished printing the whole document, which is often not ideal, but for me, it got me printing large A3 jobs on my HP deskjet 9670. -Ian Quote Link to comment
