LarryO Posted July 6, 2021 Share Posted July 6, 2021 8402 Custom's House - roof hatch frames in ventilation shaft.pdf The size of the HSS in section B-B is as labeled using the 3d square tubing. 1. BUT when rendered in the section viewport it is only 74mm as evidenced by the sectioned tubing being slightly larger when they are all the same size. I had to fake the vertical dimensions. 2. Also the solid line parallel to the bottom edge should not be there. The smoothing angle is set to 5°. These lines appear unpredictably in part or whole from radial point(s) along an extrusion when said solids have been operated upon by one of the 3d modelling tools (add, subtract, section, etc.). VW Model file is 12.8MB Quote Link to comment
LarryO Posted July 7, 2021 Author Share Posted July 7, 2021 (edited) I was able to reduce the file size while retaining the rendering error for anyone capable of hunting down this bug causing these dimensional errors. File attached. (edit: error is still present in today's SP4 602791 update) VP RENDERING INCORRECT OBJECT SIZE.vwx Edited July 7, 2021 by LarryO Quote Link to comment
