VW 2020 - Is it possible to export multiple sheet layers as a batch?
rlb
Quote
Is there a VW (2020 Designer SP6) alternative to exporting DWG and image files one by one?
I have 15 sheets in a project and doing it individually is a real drag.
Thanks for any help!
RLB in Brooklyn
The Publish command is where you need to look. Menu > File > Publish
Its a big slightly complex dialog that can accomplish a lot, and it is worth spending some time getting to grips with it. From here you can publish drawings in all sorts of formats and to several different places.
