Crash after editing lights VW2021 / VW2022
bjoerka
Posted (edited)
this happens to me in vw2021 sp4
open a blank document
insert a light
deselect the light in the drawing
right click the light in the visualization panel and choose edit
pull the slider for brightness
click the "ok" or "cancel" button
vw crashes every time
can someone confirm this?
Edited by bjoerka
15 answers to this question
QA helped me locate the bug ticket that describes the crash you discovered https://jira.vectorworks.net/browse/VB-181752   Looks like the crash was macOS specific-- that's why I wasn't duplicating it.  The bug was fixed last month and has been verified fixed in VW2022 SP2.  I'll double check that it's been fixed and report back
I just verified the crash has been fixed testing one build before the fix and one after:
  VW2022 SP2 build 614210 -- has crash
  VW2022 SP2 build 615870 -- no crash
Looks like SP2 becomes publicly available in just over 1 month
  • Like 3
On 7/2/2021 at 3:17 PM, zoomer said:
Hmmh,
seems I can't even create any light !?
Red Warning in status bar :
"created Light is not visible"
VW 2021 SP4
M1 Mac Mini
macOS 12 Monterey Public Beta
sounds like you have Vectorworks Preferences -> Display -> Display Light Objects option set to Never.  Change it to Always as shown here:
You are totally right !
I did clean settings from scratch with VW 2022 Upgrade,
and forgot that setting. It was set to "Wireframe only" !
Thanks for that.
Edited by zoomer
Thanks Justin!
Still happening to me every time:
VW2022 SP2 build 619242
MacOS 11.6
iMac (Retina 5K, 27-inch, 2017); 3.8 GHz Quad-Core Intel Core i5; 40 GB 2400 MHz DDR4; Radeon Pro 580 8 GB
Seems to be tied to adjusting the brightness.  Adding the light works fine.  I will try updating VW again to make sure I have latest.  But that build should still have the fix from previous builds.
