Thomas_ Posted July 2, 2021 Share Posted July 2, 2021 On a roll with questions I know... So in one of my systems, every time I go to ConnectCad>Layout>Update Rack Elevation I end up with an 'unnamed' device on the rack layout. I can confirm this device is present somewhere in the schematic as I can go to the schematic layer, ConnectCad>Documentation>Current Layer Device Report and see a row that is an unnamed device. How can I locate this device on the schematic however so that I can either delete it (If it isn't supposed to be there which I suspect) or correct it so that it is no longer unnamed and has the correct height/width/etc.? Thomas Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted July 2, 2021 Vectorworks, Inc Employee Share Posted July 2, 2021 Hello @Thomas_, You can modify the device directly from the worksheet report that is showing you that you have such a device. Another way to go for this would be to right click on the subrow in the worksheet and click on Select Item. This will select the device and center and zoom the view on it. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
Thomas_ Posted July 6, 2021 Author Share Posted July 6, 2021 Thank you, the select item command was precisely what I was looking for. I knew you could edit in the worksheet, however I needed to know what the device was before I could edit it, which finding the device in the schematic was what gave me that information. Thomas 1 Quote Link to comment
Pat Stanford Posted July 6, 2021 Share Posted July 6, 2021 If you have rows SUMmarized so that data from multiple items are all in the same row, I don't the the Select Item option is available. Quote Link to comment
Thomas_ Posted July 6, 2021 Author Share Posted July 6, 2021 17 minutes ago, Pat Stanford said: If you have rows SUMmarized so that data from multiple items are all in the same row, I don't the the Select Item option is available. Ahh that might be why I didn't find it the first time, good to know! Thank you. Quote Link to comment
Thomas_ Posted July 6, 2021 Author Share Posted July 6, 2021 27 minutes ago, Thomas_ said: 45 minutes ago, Pat Stanford said: If you have rows SUMmarized so that data from multiple items are all in the same row, I don't the the Select Item option is available. Ahh that might be why I didn't find it the first time, good to know! Thank you. This does bring up another question, is there a way to show the quantity of summarized items? For instance in a recent system I had 8 mini-converters that summarizing would shrink them down to a single row, which is great, but I would love to be able to get the quantity at that point to still know how many are needed? Thanks! Thomas Quote Link to comment
Pat Stanford Posted July 6, 2021 Share Posted July 6, 2021 Add another column with a formula of =Count 1 Quote Link to comment
