New Forums Design Difficult to Read
Same if you use the dark mode option ....
Everything somehow harder to read.
For me the Forum UI was totally ok before, I had no wishes.
Now, when I open my notifications, half of the threads will not
find or jump to last read post, but jump back to page 1 top.
Some Threads Text will not use the whole available window
width but somehow collapse like in a mobile view.
Posted (edited)
There's a setting to adjust this, though it doesn't seem to "stick" and reverts to go back to the first comment.  Go to your name/icon at top right of page -> Account Settings -> Content View Behavior (in left sidebar)
Also, just discovered that the "edit" button is now hidden in the top right corner under the triple dots.
Edited by E|FA
Fix error and add note re edit button
Posted (edited)
^ Great !
I searched for that setting in my activity stream as in the past and did not find it.
Now i found and saw it in user settings, deactivated. Activated it now.
Hope it will work again ....
....looks good so far 🙂
Edited by zoomer
Don't see why I should change to another mode to read, was perfect before, if VW have twiddling thumb's there are lots of things to do with the core software - could start with ODBC, then sort vertical curves, then consider topological editing.
And pale turquoise is a terrible colour on a screen, esp. in tiny little blocks. Also text seems more spread out, didn't need that
