Marietta Posted May 17, 2005 Share Posted May 17, 2005 Is there a way to use saved stipple settings after you have drawn the polygons? I know you can use the saved settings by clicking on them and then drawing the polygon. Also, you can draw a polygon and use the objects from polygon tool to convert to stipples, but here there is no choice to use a saved stipple setting. It would be very nice to draw all the polygons first, make adjustments where required and then use whatever saved stipple setting you would like to the polygon, or if you want to change the setting or use another setting, to click on a stipple object and switch settings without having to go to the dialogue box to make adjustments. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted May 17, 2005 Vectorworks, Inc Employee Share Posted May 17, 2005 Use the Objects from Polyline... command for this. Quote Link to comment
Marietta Posted May 17, 2005 Author Share Posted May 17, 2005 Robert I mentioned 'object from polygon' instead of 'polyline' in my question above. When using the 'objects from polyline' tool, how do you attribute a saved stipple setting to the object? Or, if you decided you want to change a bunch of stipple objects to another setting, how would you do that without going through everything in the dialogue box each time? Quote Link to comment
