Revision/Issue Data stacking order
Is it possible to change the revision/issue data stacking order so the latest is at the top, if I turn on the "Up Page" option it just creates from the text point up which doesn't help, I would like it to appear as it does in the Title Block Manager window.
Thanks
1 answer to this question
Hello @Ben Wingrove,
Currently there is no other way to achieve this, than the way you have specified. In this case you would have to put your headers to be in the bottom of the columns, so that your texts do not overlap.
I will add an enhancements request for this, so that we can consider it.
Best Regards,
Nikolay Zhelyazkov
