Ian D
Line color to line weight conversion (long)
We are about to start work on the Federal Courthouse here in Seattle. As it is a Federal Project, we are required by contract to save the drawings for the client in .DWG format, and furthermore we will be exchanging drawings with our consultants who are all using AutoCAD themselves.
In the past it has not been an issue, because we have had relatively few drawings to pass back and forth, and we were in control of the layering and lineweight situation. For this project in particular, we are required to use a subset of the CAD standards that are federally mandated.
The question is this: is there a way to save the lineweight-to-color conversion values as a table somewhere so that we can batch import/export DWG files into/out of Vectoworks?
Is there someone that has written a VectorScript to do this?
Is there someone you would recommend to write a Vectorscript to do this?
Nemetschek Tech Support has stated that there is currently no way to save these values in tabular form. (similar to ctb and pcp files in AutoCAD)
Nemetschek Tech Support has suggested that lineweights can be used in AutoCad 2000. Unfortunately we don't have control over what the consultants use, and as stated above, we are mandated to use DWG's or DXF's with line colors.
This is going to be a very big project, and anything that can be done to automate this process would be greatly appreciated.
I would even recommend putting this on a wish list for the next version of Vectorworks.
If you look at the VectorScript Function Reference that comes with VW, in its appendix, you will find the table of VS preferences for DWG/DXF:
DXF Preference Selectors
Preference
Selector
Preference Data Type
Function
Auto Units300
TRUE or FALSE
Pref
Units
301
INTEGER
PrefInt
DXF Units Per Inch
302
REAL
PrefReal
Auto Model Space Scale
303
TRUE or FALSE
Pref
Model Space Scale
304
REAL
PrefReal
2D 3D Import Handling
305
INTEGER
PrefInt
Map Layers to Classes
306
TRUE or FALSE
Pref
Convert MLines to Walls
307
TRUE or FALSE
Pref
Convert Rays and XLines
308
TRUE or FALSE
Pref
Scale Dash Lengths
309
TRUE or FALSE
Pref
Dash Length Scale
310
REAL
PrefReal
Auto Block Attribute Handling
311
TRUE or FALSE
Pref
312
INTEGER
PrefInt
Auto Point Handling
313
TRUE or FALSE
Pref
Convert Points to Loci
314
TRUE or FALSE
Pref
Point Symbols are Guides
315
TRUE or FALSE
Pref
Map Colors to Line Weights
316
TRUE or FALSE
Pref
Set Line Colors Black
317
TRUE or FALSE
Pref
Paper Space Units
318
INTEGER
PrefInt
Auto Scale Dash Lenghts
319
TRUE or FALSE
Pref
Group Record Fields
320
TRUE or FALSE
Pref
Auto Line Weight Handling
321
TRUE or FALSE
Pref
I actually meant to format it better than that! [Razz] But I guess my point is that VectorScript does not at the current time support the lineweight tables you seem to be asking for. I have forwarded the wishlist item to our DWG guru.
There's no way currently, tho VW should remember your settings for the session and fill the dialog with previously chosen values.
The best way to handle this currently is probably to turn off color to lineweight mapping and write a script that modifies the drawing after import and before export, or maybe just modify a copy of the drawing when you need to print and work in colors the rest of the time.
Often the objects will all come in as "by layer" which can map to "by class", so you could possibly just modify class attributes with a script.
Well, you can't beat straight forward honesty!
However, it is like a warning, "mine field ahead" for those of us who are consultants, mechanical/strctural/electrical/civil/fire protection/landscape engineers who are out there on "macs" and have to deal with reality. They never promised us a rose garden. I love V'works, it's so much better than A'cad, but all the interface in the world, won't satisfy the need to live with the standard. And to add insult to injury, the hardware is a hell of a lot cheaper. Is it better to pay 50% less for hardware and 400% more for software, that is the question-to be or not to be... Guys, you got to figure it out
quote:
And perhaps the best way to do that is my free 'Cloning around' collection on VectorDepot.
Once you have configured your class attributes (well, twice - for import & for export) you can save the settings to be used in new/other documents.
I have a an idea. I would work to my advantage, may be not yours, for VW to have the ability to print all as black and white, which it does have, but with the exception of the gray scales. In this way all colors would print black, but all gray scales would remain gray. Then I could draw as I am accustomed to black screen colors representing line weights, and grays being grays.
