3D MODELING
Chris T
Chris, you probably know about multiple extrusion for tapering objects.
I would try using a nurbs / extrude along path for the curving eave. For the path, you can create a 3d polygon that basically traces the eave line.
Robert - is there any reason not to use this approach? I've tried the polygon / "short segments" approach in the past for curving eaves, but it would be nice to get some more precise geometry and better 3d rendering using nurbs. The big question is whether this creates a huge number of calculations for rendering and other tasks. I know that when I take a nurbs extrusion and cut a 3d section from it I get an enormous number of 3D polygons.
[ 09-01-2003, 03:49 PM: Message edited by: P Retondo ]
THANKS FOR THE REPLIES.
THERE IS NO WAY TO CONTROL THE PILASTER OR COLUMN SIZE. CAN'T DO A COLUMN 8X20"
I USE THE EXTRUSION TO DO THE COLUMNS AND ROOF.
I MADE A 2D POLYGON SECTION OF THE WALL AND CURVED ROOF THEN PUT THE LAYER INTO A FRONT VIEW AND EXTRUDES THE SECTION TO THE LENGTH.
LOOKS GREAT RENDERED BUT NOT IN PLAN.
YOU CAN CREATE HOW YOU WOULD WANT IT TO LOOK IN 2D PLAN BY MAKING A SYMBOL WITH THE 3D EXTRUSION.
IT WOULD BE NICE IF VWA CAN TAPER WALLS AND HAVE RECTANGLE COLUMNS
