Matt Hagen Posted June 22, 2021 Share Posted June 22, 2021 Is anyone else having issues with window ID's showing up reversed on the elevation viewports when using WinDoor? When I go to the floor plan layer in the model it shows correctly. Ive attached two images, screenshots, one of the viewport with the reversed ID, the other of the model showing the correct ID orientation. Quote Link to comment
Ross Harris Posted June 25, 2021 Share Posted June 25, 2021 Since data tags arrived, I've stopped using the windoor tags and made custom data tags that you can tag windoor objects in either the design layer or viewport annotations - so much more flexible. There is a video on the ozcad site covering them and also how to display user field data as well. Quote Link to comment
Boh Posted June 25, 2021 Share Posted June 25, 2021 I haven’t come across this before where an ID tag shows correctly in the DL and reversed in a VP. Can you post the file? I usually try to have my Windoor objects unflipped and umirrored in walls which sorts most issued with elevation ID tags. As @Aspect_Design mentions, the data tag tool is pretty gd withWindoor objects. Quote Link to comment
Matt Hagen Posted July 5, 2021 Author Share Posted July 5, 2021 Thanks all. I will try the data tags. File attached as requested 31 Mariners Cove, McDonald House.vwx Quote Link to comment
