default class changing
Is anyone else having issues with the default class changing to random classes? Typically I work in 'none', then change as required but in the last week I've noticed the class changes to all sorts of random classes with no warning.
Im using VW 202-SP 3 windows
Thanks
Matt Hagen
If you use the Eyedropper tool with "Pick up sets defaults" checked, then the active class will change to whatever the class the object you pickup the attributes from is on. Perhaps check this option is unchecked?
Glad it got sorted. Same thing happened to me a while back. I almost always leave the None class as the active class but couldn't understand why the active class was changing. Of course I didn't notice until after doing lots of drawing and edits, so a lot of things inadvertently got placed on some random class.
 That setting is great for setting default settings for parametric objects, especially when setting up templates but otherwise it should be left off!
