hyperlinking a section/elevation line!
I am trying to link my sections markers as a form of hyperlink so that when it is a published PDF, one could click on the section marker and be taken to that sheet. I tried using the hyperlink tool but it shows up as a title/link. I want the section cut symbol to be the hyperlink itself. Is there a way to do this??
I have no idea how it will respond in the PDF, but making a symbol into a hyperlink is totally doable.  Just drop in a hyperlink object, then click on the Edit button in the Object Info Palette.  It should launch a dialog box allowing you to change the hyperlink label, function, and appearance.  There is a box on the right of the dialog that will allow you to select a symbol.
I have not tested the hyperlink in an exported PDF.
