Plug-in that works with Big sur
hisa
I want to make a Plug-in that works with VW2021 and Big sur 11.4. If I build the sample "TesterModule" as is, it works on High Sierra 10.12.6, but not on Big sur 11.4.
Gatekeeper cannot be executed via the Internet because the developer is unknown. It works when I build it myself and use it myself.
I think the problem is that the developer is unknown.
If you try to set Development Signing (Code Signing) in Xcode, the developer will not be unknown, but it will be an "incompatible plug-in" and will not be recognized.
What should i do?
There are several build environments.
1) Big sur 11.4 Xcode 12.5
2) High Sierra 10.12.6 Xcode 8.1
Download the zip with a browser such as Safari.
Force the downloaded user to use the xattr command?
Is it possible to solve it by executing the xattr command and then uploading it to the Internet?
No, the whole quantize stuff is a feature of macOS. As long as you use Safari, you will have the problem.
May be instead of zipping it , you could pack it in a signed and notarized DMG. (However, personally, I have only put installers in such DMG, not a single VW-Plugin that  user could copy. Therefore I do not know it it works.)
