Solid Boolean not producing an Output.
Hi Antonio,
Thanks for giving it a shot. Do you think there is a data flow issue, as it passes through the second "valve" condition node? Once, I connect the solid boolean to the copy node and run in debug mode, data doesn't flow through the second valve node.
