P Retondo Posted July 1, 2003 Share Posted July 1, 2003 I have a building full of windows with assigned ID's that were used to create a window schedule. Now I want to attach an ID label to each window so that I can see the numbers more easily. But, it seems that the association with the Window record ID field is one way only - i.e., the window record can be changed by the value in the ID label, but not vice-versa. Is there any way to get the label to accept the current Window ID value without entering it manually in the ID Label dialog box? Then I could see my ID number with two simple clicks per window. Quote Link to comment
