kgreenley
Dimensions Not Showing Up In Viewport
When cropping design layer to create viewport, the dimensions included in crop are not showing up, on sheet layer.  Am I missing something obvious here....
Check that the Dimension Class is set to be visible in the viewport.  Click the Classes... button in the OIP with the Viewport selected.
Is the Dimension Class visible in the Viewport, or the Class that the Dimensions are assigned to?
Solved issue by checking the  "Project Screen Objects" box.  Dimension class was set to "visible", BTW.  Any other objects that will behave similarly, in viewports?
