kgreenley Posted June 10, 2021 Share Posted June 10, 2021 When cropping design layer to create viewport, the dimensions included in crop are not showing up, on sheet layer. Am I missing something obvious here.... Quote Link to comment
Pat Stanford Posted June 10, 2021 Share Posted June 10, 2021 Check that the Dimension Class is set to be visible in the viewport. Click the Classes... button in the OIP with the Viewport selected. Quote Link to comment
bcd Posted June 10, 2021 Share Posted June 10, 2021 Is the Dimension Class visible in the Viewport, or the Class that the Dimensions are assigned to? Quote Link to comment
kgreenley Posted June 10, 2021 Author Share Posted June 10, 2021 Solved issue by checking the "Project Screen Objects" box. Dimension class was set to "visible", BTW. Any other objects that will behave similarly, in viewports? Quote Link to comment
kgreenley Posted June 10, 2021 Author Share Posted June 10, 2021 And thanks for the replies!! Much appreciated! Quote Link to comment
