Yoginathaswami Posted June 10, 2021 Share Posted June 10, 2021 Aloha, been very long time since I posted here! I am not very familiar with Worsheet in VW--rarely use it. I want to create worksheet that will give a list of Class in the file and total count of objects within the class. I have tile layout that has different sizes. I put each size in an individual class. It will be cool to be able to pull the count of tiles in each class along with the class name. I was playing around and was able to create the following Database with criteria "class is xyz" Function: "class" on the first column Function: "count" on the second column But it is not giving what I wanted... Any thoughts will be greatly appreciated! Thank you VW2021iMac Quote Link to comment
Yoginathaswami Posted June 10, 2021 Author Share Posted June 10, 2021 Figured it out😃 Quote Link to comment
Pat Stanford Posted June 10, 2021 Share Posted June 10, 2021 The way I would do this is to create a database with a Criteria of All Objects. If you need sub objects then turn on the Symbols, Plug-ins, etc. options also. Formulas in column headers of =C (gives the class name) =Count (should return 1 for each object) In the Class column set the option to SUMmerize In the Count Column set the option to Sum Values. You should then have a list of every Class used in the file and the number of objects in that class. Quote Link to comment
Yoginathaswami Posted June 10, 2021 Author Share Posted June 10, 2021 Thanks Pat! Once I checked the options SUMmerize and Sum Values, it worked as intended 🤙 Quote Link to comment
