Sam Jones Posted June 4, 2021 Share Posted June 4, 2021 Does anybody have an example of, or know where I can find an example of, the implementation of a progress dialog? Quote Link to comment
Vectorworks, Inc Employee Judah Warshaw Posted June 4, 2021 Vectorworks, Inc Employee Share Posted June 4, 2021 I would start with the following article on the Developer site:https://developer.vectorworks.net/index.php/VS:Progress_Dialog Quote Link to comment
Sam Jones Posted June 4, 2021 Author Share Posted June 4, 2021 I looked at the above. After a bunch of trial and error, I was able to build an example below the "====" line, but I really don't understand what I'm doing. Here is what I am tripping over. These procedures/function have obvious functionality and are understood. PROCEDURE ProgressDlgClose; PROCEDURE ProgressDlgEnd; FUNCTION ProgressDlgHasCancel:BOOLEAN ; PROCEDURE ProgressDlgOpen( title :STRING; canCancel :BOOLEAN) ; PROCEDURE ProgressDlgOpenDelay( title:STRING;canCancel:BOOLEAN; delaySec:INTEGER) ; PROCEDURE ProgressDlgSetBotMsg( message:STRING ) ; PROCEDURE ProgressDlgSetTopMsg( message:STRING ) ; only sort of obvious. I expected it to be in the position of the SetMeter String Then there are these: PROCEDURE ProgressDlgSetMeter( message:STRING ) ; "Set progress meter message of a progress dialog."With minimal testing this became clear. It would have been nice if it had beem named "SetProgressDlgLabel" or "ProgressDlgSetLabel". "...SetMeter" is opaque until after one figures it out. PROCEDURE ProgressDlgStart( Percentage :REAL; LoopCount :LONGINT) ; "Start a progress context. This defines progress percentage and loop count for ProgressDlgYield calls. LoopCount is fit in the Percentage of the progress.""Percentage". Percentage of what going in what direction? "LoopCount". "LoopCount" ???? What Loop? What Count? PROCEDURE ProgressDlgYield( count:LONGINT ) ; " Increases the progress. This must be called between ProgressDlgStart and ProgressDlgEnd and defines the LoopCount index.""count"??? Counting what? All the examples have this set to "1" What does this do? Where in the loop or in the survey by criteria is this needed. What happens if the value is not "1", maybe "2" or maybe "0"? It is defined as a LONGINT, so it would seeem a bunch of values can be expected. I really don't understand this call, but I put it in each iteration of the repeating task. ============================================================== PROCEDURE ProgressDialogExample; VAR index :INTEGER; x1, y1, x2, y2 :REAL; progress :LONGINT; BEGIN x1 := 10; y1 := 10; x2 := x1 + x1; y2 := y1 - y1; ProgressDlgOpen('Draw Squares', TRUE); ProgressDlgSetMeter ('Drawing Squares First Half'); ProgressDlgSetTopMsg ('Top'); ProgressDlgSetBotMsg ('Bottom'); ProgressDlgYield (0); { start at 0% } ProgressDlgStart(100, 30); FOR index := 1 TO 30 DO BEGIN message('index = ', index); IF index = 15 THEN ProgressDlgSetMeter ('Drawing Squares Second Half'); RECT(x1, y1, x2, y2); x1 := x1 + 5; y1 := y1 + 5; x2 := x1 + x1; y2 := y2 - 5; ProgressDlgYield (1); { Increment the progress bar } IF ProgressDlgHasCancel THEN index := 60; wait(1); END; {FOR index := 1 TO 60} ProgressDlgStart(0, 0); ProgressDlgYield (0); ProgressDlgEnd; ProgressDlgClose; Redrawall; clrmessage; END; RUN(ProgressDialogExample); Quote Link to comment
Vectorworks, Inc Employee Judah Warshaw Posted June 11, 2021 Vectorworks, Inc Employee Share Posted June 11, 2021 I'll try to clarify some of the calls, to the best of my abilities. I can't really comment on the naming, since that ship has sailed long ago. Keep in mind that many function calls are exposing inner functionality for public use, and the function and variable names will be created to reflect that. Lets examine ProgressDlgStart. This tells the dialog that how much of the work you want to be show. If for example you have ten steps that you are going to be doing and you want to update the meter text after each step, you would give the percentage as 10 for each step. Maybe you have three steps, but one of them reflects 50% of the work, one 30% and the final 20%. You would be calling ProgressDlgStart three times, each with a different percentage. Now each of these steps can be broken down into how many increments will be in the progress bar for that step. Let's take our example of 50, 30 and 20 as a division of labour, and you have 10 objects you will be working on during each of the operations. You would call ProgressDlgStart( 50, 10 ). You are saying "fill the progress bar until 50 percent of it is filled, and do it in 10 incremental parts." Each time the progress bar fills a little big, it will be 1/10th of 50% of the bar. That is you LoopCount. When is the progress bar incremented? When you call ProgressDlgYield. You are saying how many of the previously defined LoopCounts you want to increment the bar. It also gives you an opportunity to check if the cancel has button has been clicked. I know this may not be as clear as possible, but with a little playing around I think it would clarify itself. Does this help at all? 1 Quote Link to comment
