MINDI Posted June 3, 2021 Share Posted June 3, 2021 Hi all, I was following this tutorial (https://forum.vectorworks.net/index.php?/articles.html/articles/how-to/custom-title-block-r79/) to edit the title block. trying to link the text to the record format so I can edit the info from the Object Info. But I do want a few text boxes can collect the info from the Sheet Number and Sheet Title, so that I don't need to type from sheet to sheet. The detail of my issued can be found in the screenshot. I wonder which step is wrong from my process. Thanks!! Quote Link to comment
0 Vectorworks, Inc Employee Nikolay Zhelyazkov Posted June 4, 2021 Vectorworks, Inc Employee Share Posted June 4, 2021 Hello @MINDI, The first thing that we have to figure out is which version of VW are you using? Because the demo video you are watching is a bit outdated. If you are using VW 2018 or above, then I suggest that you use the Title Block Border object - here is the help for it to get you started https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FSetup%2FEditing_a_title_block_border.htm%23XREF_60213_Editing_a_Title&rhsearch=title block border&rhsyns= . You can also check for video lessons in the VW university here https://university.vectorworks.net/. If you are using VW version 2017 or lower, then the demo video you watched should be relevant and you should be able to get the data using the symbol and linked text values and the old Sheet Border object. Let me know if you need additional information. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
0 MINDI Posted June 25, 2021 Author Share Posted June 25, 2021 @Nikolay Zhelyazkov Thanks Nikolay, I ended up solving this issue by creating a title block! Thanks! 1 Quote Link to comment
0 unearthed Posted June 28, 2021 Share Posted June 28, 2021 On 6/4/2021 at 5:33 PM, Nikolay Zhelyazkov said: Hello @MINDI, The first thing that we have to figure out is which version of VW are you using? Because the demo video you are watching is a bit outdated. If you are using VW 2018 or above, then I suggest that you use the Title Block Border object - here is the help for it to get you started https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FSetup%2FEditing_a_title_block_border.htm%23XREF_60213_Editing_a_Title&rhsearch=title block border&rhsyns= . You can also check for video lessons in the VW university here https://university.vectorworks.net/. If you are using VW version 2017 or lower, then the demo video you watched should be relevant and you should be able to get the data using the symbol and linked text values and the old Sheet Border object. Let me know if you need additional information. Best Regards, Nikolay Zhelyazkov @Nikolay Zhelyazkov Would that older process also work in VW 2012? 1 Quote Link to comment
0 Vectorworks, Inc Employee Nikolay Zhelyazkov Posted June 29, 2021 Vectorworks, Inc Employee Share Posted June 29, 2021 7 hours ago, unearthed said: @Nikolay Zhelyazkov Would that older process also work in VW 2012? - I cannot tell for sure. If there is Sheet Border object in VW 2012 then this should work. Quote Link to comment
MINDI
Hi all,
Thanks!!
4 answers to this question
