ZoltanE Posted June 2, 2021 Share Posted June 2, 2021 I'm an Unreal developer working with a client who created a scene in Vectorworks. My task is to transfer it to Unreal so I used Datasmith. The process works as expected however I end up with meshes which are fully or partially inside-out. (See the attached image of a box.) The issue seems independent from export detail level. I'm using Unreal 4.26 and Vectorworks Spotlight 2021 SP3 1 (Build 588748) 64 bit. Quote Link to comment
zoomer Posted June 2, 2021 Share Posted June 2, 2021 Yes, seems that VW never really cared about Face Normals for their geometry. You can find flipped Normals especially in the more complex Plugin Object created Geometry. Especially from Slabs, Stairs and, at least in the past, even standard Extrudes had one Face flipped. Usually that is a problem in any 3D Mesh based Software like Game Engines, Modo, Blender (?), .... But not in Cinema4D, which Cine Render Engine is also integrated in Modo. So you will not notice sloppy Face Orientation. The only reason is that C4D Renders every Material "2-sided" by default. You will only notice Problems in C4D, if you manually deactivate 2-sided or check for Face Orientation. In Modo you would have to activate 2-sided for any Material instead, as most times it may not be possible to repair all Meshes. And even when 2-sided on, there can still be issues in advanced OpenGL Viewports or visual problems for Global Illumination calculation. The problems you mentioned for Datasmith were also seen in Twinmotion, via Datasmith, which has 2-sided OFF by default too. But if I got that right VW sends a 2-sided Tag for any Material when exporting. Could just be that this does not work in any case for Datasmith export, which seem to be still in WIP. I am sure there will be more fixes in Datasmith Export for VW SP4 but don't know when it will be released. 1 Quote Link to comment
ZoltanE Posted June 2, 2021 Author Share Posted June 2, 2021 Oh, by default 2 sided materials were created but they just covered up the core problem... with inside-out meshes, lightmapping will produce unusable results, that's why I need to fix the meshes somehow... I hoped for an automated way because manual labor is both slow and expensive. 1 Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted June 2, 2021 Vectorworks, Inc Employee Share Posted June 2, 2021 We tag Datasmith materials as two-sided, Twinmotion and Unreal Editor use those tags to show correct shading. 1 Quote Link to comment
zoomer Posted June 2, 2021 Share Posted June 2, 2021 (edited) 15 minutes ago, ZoltanE said: Oh, by default 2 sided materials were created but they just covered up the core problem... with inside-out meshes, lightmapping will produce unusable results, Yes, I also think that 2-sided hammer ist just a workaround and does not really help at all in some situations. That is why I would prefer clean geometry from VW. I postulate that since nearly a decade, but it does not seem to share development's highest priorities. I don't know if you have access to C4D, Modo, .... where first one has really good options to clean up meshes, and export to UE from there. Otherwise you could just export a FBX into Blender, which repair options are AFAIK not bad either. Edited June 2, 2021 by zoomer 1 Quote Link to comment
ZoltanE Posted June 2, 2021 Author Share Posted June 2, 2021 Oh well I guess I will set up the workflow for manual cleanup. Thank you for the help Zoomer! 2 Quote Link to comment
jbrem003 Posted March 6 Share Posted March 6 This problem is causing me a supreme headache and seems to be very arbitrary at best. What is the process for manual cleanup? Has there been any progress people have seen from Vectorworks? I'd really love to make use of the datasmith tool, but this render issue is causing project defeating headaches. Quote Link to comment
