MFpsrig Posted June 2, 2021 Share Posted June 2, 2021 Hi, I'm currently working on a stepfile that I have imported. Now I'm trying to simplify it to make it a nice looking but manageable symbol. It's a step file with around 4000 objects... my guess from removing some of them manually is that most of them are nurbs. Now the question is, can I select all the nurbs somehow? To remove them all in one go? Quote Link to comment
Tom W. Posted June 2, 2021 Share Posted June 2, 2021 If you simply want to select every NURBS Curve in the file, use the Select Similar Tool set to 'Object Type'. But do you want to remove every last one or just a selection? Quote Link to comment
MFpsrig Posted June 2, 2021 Author Share Posted June 2, 2021 @Tom W. Oh, that was easy, I just had the settings set the wrong way for it to work... At the moment I'am experimenting with what works so I'm not sure.. I'm still considering remaking it completely from the ground up myself since the symbol probobly will end up pretty heavy anyway. Thank you for the help! 1 Quote Link to comment
